WTB: stock rear 80 series coil springs
murf
Lifer
Scottsdale, Arizona
One of my techs at work here is lifting his 4Runner and is looking to buy a used set of rear 80 series rear coil springs.
Let me know if you got a pair collecting dust in the garage. He's got some cash for ya!
Murf
Murf
I have a new pair of 2" front coil spacer for a 4R if he is in need
I've got a set, IIRC
thanks Phil, ILl let him know but I think the fronts are already taken care of.
Found!
Thanks BluesDawg! :clap:
Two less item to sit on your "special shelf" over at Kevins shop.:hillbilly:
Found!
Shelf, he has a whole corner!:hillbilly:
The trick will be determining which set are his, lots of them here, likely just give him Rich's or Jim's, they are on top of the pile! :hillbilly:
I'm guessing 2nd gen Runner? The Cruiser coils give a bunch of lift, (4" maybe?) more than he is thinking/wants? The LX coils work better for that application, slightly softer, slightly less lift. Also, stock size/spec '80 shocks work well, bolt right on and ride well. Have a set of old/used ones, if he wants to test fit that theory?
Yes it is a second Gen. I talked to him and he apprecaites your feedback and agrees the LX coils would be better for what he is looking for.
So.....you have a set of those in the stash? That would be great if you can pull those for BDawg instead.
FYI, he already has some Toyota Bilstein shocks, but thanks.
I have a set of lx coils
Yes, the cruiser coils give a 4" lift. Will definitely need a pan hard bar drop bracket, the awkward steering takes some getting used to...
