Wrappin'
Discussion in '40- & 55-Series Tech' started by Gumby, Feb 9, 2004.
  1. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,192
    648
    Dec 13, 2002
    Knee deep in hookers and gin
    I went out to test the SOA on my 40 Saturday and noticed the expected wheel hop, so Sunday I built a Woody-style anti-wrap ladder bar. I also welded the rear according to Woody's pics. Pretty easy to do both with the right materials and tools. I haven't taken any pics 'cause it looks just like Woody's pics, except I went right to the 3 heim set-up and used 1" x .125 DOM and weld in inserts left over from my steering.
    Welding safety note. While brake cleaner is an excellent choice for cleaning the diff gears before welding, and non-flammable may be a better than the flammable kind, make sure there is no puddle of cleaner in the carrier. Non-flammable brake cleaner is also known as Chlorinated. I was welding away and sucked in a bunch of chlorine gas. It burned and I felt crappy for the rest of the day. Probably not a good thing.
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,383
    Media:
    17
    Albums:
    1
    755
    Oct 1, 2003
    MN
    Good advice Todd. It is amazing the gasious combos that can be cooked up when you are welding anything.
  3. REZARF
    REZARF
    4,262
    1,326
    Sep 8, 2003
    Bozeman, MT
    Was using some rust breaker fluid the other day when I was disassembling my 8274 warn winch brake housing and decided to put a little heat on the keyed shaft when whoala! I had a table of warn winch flambe'... :whoops:
    Managed to not freak out and get the flames out of the garage and then put the parts out.
    Ahhhh, nothing like scaring yourself with a torch and chemicals in the morning to get your blood flowing. ;)
    Drew <><
