WOT throttle occasional stall, with excessive supper acceleration otherwise!
So this 01LX w/360K miles will sometimes stall when “pedal to the metal ((PtTM) (sudden full depression of gas pedal))” as they say. When gas pedal slowly depressed, it never stalls. In fact once it has stalled during a PtTM, it doesn’t generally repeat.
I only need to let of the gas pedal after a PtTM stall, then depress at a normal easy pace again, and acceleration is normal. Then I can depress to WOT rapidly again, and it is fine most times. But the acceleration is more than any none VVT I’ve driven. In fact kick the my head back, may even have more acceleration than a well turned VVT 4.7L. More like a turbo charged engine.
Test by the book performed at 79F:
Why does throttle do nothing at times (stall) and only during very rapid pedal depression?
Why, when working without stalls, is acceleration so strong?
- Fuel pressure: Okay @ 44PSI.
- TPS, Okay @ 1.697 OMH.
- Throttle control motor, Okay @ 3.3 OMH.
- Clutch, Okay @ 5.3 OHM
- Accelerator pedal position sensor, Okay @ 1.872 OHM.
