- Thread starter
- #1
So a while back, I bought my FJ62 and have been working through issues.
So when I was driving it back from Sacramento to San Diego, I got an engine warning light about 1/3 of the way home. I read this as code 11, but I buddy said it was 22.
I was exhausted and agreed on code 22. So focused on fixing the temp sensor. Made it home safely.
Since then I replaced water temp sensor, spark plugs, distributor, plug wires, recharge A/C, replace radiator hose, egr modulator, valve adjustment and normal fluid changes. After all that, I am now getting code 43 and nothing else. Looking at the video again, I read code 11. So taking these two codes into account, I am thinking that it may be a bad ECU. I've misplaced my multimeter so forced to get another but once in tomorrow, I'll go through and double check everything.
The truck starts well. I need to give it a little gas to crank at times but idles with no issues. Once running, it runs great. I was driving it around town until I experienced the death wobble. Just replaced the TRE and working through the alignment now.
Now I have a bunch of other little things to fix.
- bad oil pressure gauge
- front flood lights not turning on
- fix rocker switches
- belts need replacing
- few other small things
