Wont shift into gear
Boulder CO.
Ok, if i am driving and i come up to a stop and i don't down shift through the gears it wont go into second or first, sometimes it wont go into any gear. Occasionally even if i do down shift it still wont shift when i stop.
I just replaced the master cylinder since it was leaking and figured that there was air in the system and that's why it was doing this. Nope, its still doing it.
Do i have to replace the slave also? Anything else it could be?
Thanks in advance!
The slave sounds like a good bet to me. Make sure the little pushrod is adjusted properly though. Just FYI, I picked up rebuild kit from one of the chain auto parts stores for around $7 or $8, and it's been fine for over a year. If your slave isn't pitted, this is probably a good, cheap fix.
slaves are cheap...$25
