I'm in the process of putting a Chevy 350 and 700R4 in my 72 FJ40. I'd like to retain the stock oil pressure gauge and Water temp gauge. Is this possible? If so, how do you do it?
Thanks,
Flash
Thanks,
Flash
For old school SAE engines, we've sold the adapter fittings for the past zillion years. If you can do it without adapters---good for you. Newer metric engines pose newer problems:
(a) Your metric temp sensor will screw into the newer metric motor, but the thread pitches are different, consequently your sender will not get tight. We recommend mixing two part epoxy and gluing the sender into the motor. If you do this, make sure you screw in on as much angle as possible (digging male/female threads into each other) to have good metal to metal ground as the epoxy sets up.
(b) Your metric oil pressure sender will in fact screw into 1/8th NPT, but commonly your new donor engine will also have an "oil pressure sensor" that must also be included into the system. Sometimes this requires some local parts store fittings to get both items (sensor and sender) installed into a common "T" fitting?? There are other ways around this--PM me for more details.
Not a problem, way to go Mark!!!!!I have put a lot of the Toyota sending units in Chevy engines that have been transplanted into Cruisers... No special adapters, just the OEM Toyota seat with the OEM Toyota sender screwed into the chevy ports I have 5 at the shop right now that are done this way. Every one of the senders seated tightly and none of them has ever leaked.
Mark...
the OEM "adapter for the water pressure guage will screw into and seal in the chevy
the OEM oil pressure fitting will too/ it is a metric pitch that is so close to NPT as to not matter
no adapters needed.
BTDT
Mark...
