Wiring????
Twin Falls Idaho
OK I searched an read about the trailer wiring harness hookup. I NAPA actually had one in stock but when I tried to hook it up the plugs were square? not the same shape as the plugs behind the taillights. THe pins were the same. Now maybye I got the wrong plugs. I did't remove any panels just the taillights and peeled the foam off the connetors. Are there more plugs back in further? Like I said the pins were the same but the shape of the plugs were different. I just peeled the foam off the taillight plugs and tried to plug it in there. HELP?
DJFORESTA the main "trailer wiring box" is in the right side aft cargo panel . just pop the panel loose and you will see the connections. you will have to run one of those wires to the left side.this is all ass umeing you have the correct "kit" good luck.
