wiring
in my little world
need wiring help now ready to purchase
ez go or painless which is better quality and easier to install. what would you buy???
neither is easy or painless - install difficulty is the same
you need a factory wiring diagram and reconstruct some circuits the Toyota way if you are using OEM switches, particularly hazard/blinkers/brake lights
the easy is cheaper - I bought the Painless :meh:
x2 Both are pretty much set up similarly. I went with the Painless because it came with my rig.
Tons of threads on this too.
I took my sweet time by crimping, soldering, and heat shrinking every connection. I had one screw up by not using the Toyota wiring diagram. I just fixed that tonight now the cruiser shuts off when I turn the key off.
....now the cruiser shuts off when I turn the key off.
:lol: yeah, that should help with gas mileage
I crimped weatherproof connectors and heat shrunk, didn't solder
I also relayed every major consumer :D
I am running stock alternator
I used the Painless kit. It was not painless. But overall not that difficult. Just make sure you lay the kit out and pre-route the wiring. Lots of planning and a good Toyota wiring schematic are a must.
+1 on the Painless. I have one in my 40 and haven't had any trouble in 6 years.
