SLCFJ62,
I understand your schematic and I tried wiring it up this evening to no avail. I can't get the two 4 PIN relays set up correctly. The 4 PIN relays are in the "open" position until activated. Your schematic shows the 4 PIN relays grounded when "closed" which is what I need but cannot achieve. How do I set up the 4 PIN relays to start off grounded (or in the "closed" position?)
Hmmm...There should be 5 pins. Two for the coil, one COMMON, and a normally open (NO) and a normally closed (NC). If your relays only have 4 pins, then you must not have a NC connection. Those relays would be good for turning on a light, but not for what you are trying to do with the seat motor. Need a NO and a NC connection. The COMMON pin connects to the motor UP or DOWN, the NC connection goes to ground, and the NO connection goes to the Antenna switch which switches in 12V . Let me edit the diagram and repost. Sorry about that.
