My rear wiring harness was butchered by a PO during the installation of a trailer connection. I'm trying to restore the harness and routing to get it as close to factory original as possible.
Below is the only helpful photo I have of the right rear corner of the FJ40 that shows the routing of the harness down the right side of the frame then over the round cross member and then through a recess in the top of the rear corner frame brace to the right rear tail light.
I don't have any photos that shows the path of the harness across the rear of the FJ from the right tail light to the left tail light.
My guess is that the harness was routed above the frame in the space between the tub and the frame. Is this correct or did Toyota route it under the frame?
If anyone has photos of the factory correct routing I'd appreciate it if you would post them.
Thanks
Thanks
