GMSilk_Fj60
Greetings all.
I just put a pretty standard OME lift on the truck with the only problem being the rear shocks were frozen on top. I got them with a little heat and they broke free but may have also burned some of the wire that runs by on each shock tower. You can just barely see the wire I’m talking about between the body and frame by the top shock bolt.
I’m looking through the FSM but not having much luck...
For the first time ever the dreaded ABS, VSC, Brake lights combo has come on. Did I cut the rear brake/speed sensors? Can they be spliced and repaired?
