Wiring 76 wiper motor to Switch Pro
Seattle
3_puppies
Helena MT
are you using an aftermarket wire harness?
I didn't look at your link about the switch.
I thought you were just using a different switch, you could get a good used switch and use it.
Engineer8000
CAPE FEAR ELECTRONICS
Supporting Vendor
SOUTHPORT NC
I think something like this would work using a couple automotive relays. I would get relays rated for inductive loads since you are interrupting the current from the motor windings.
Seattle
Yes, aftermarket. The switchpros rcr force 12. I'm really pressed for room to add switches.
Following, as I'm thinking doing the same thing to my 74.
OP, do you have a build thread on yours?
I do have a build thread, but have not updated it in awhile. I'll update it.
Thanks @Engineer8000 .
I think I'm understanding your drawing. And I don't know inductive load relays so I appreciate the pointer. This is exactly what I needed.
Engineer8000
Supporting Vendor
SOUTHPORT NC
A Bosch 0 332 209 161 would be a good choice for the relays, they have a good motor load rating. Bosch uses a resistor across the coil to limit EMI so the flyback diodes should not be required. Look at your switch panel literature a see what it says about using with relays. The relay coils only draw 140 mA so you can use low current switches.
