Wire routing from dash area to overhead console, 75 series Troopy?
Metro NY
Anyone know if it's possible to fish wires through the a-pillar on either the driver or the passenger side in a 1995 troopy?
Or possibly tell me how the wire for the roof dome light is routed?
I'm trying to wire up some things at the rear view mirror and or dome light area, possibly an overhead console.
Hello,
The dome light is wired from the fuse box through the door.
There is a harness that runs from the fuse box along the door sill. Then it enters the B-pillar and goes inside it all the way up to the dome light.
If you take out the floor mat and the scuff guard you can see this harness.
Newer model Troopies have plastic panels over the A-pillar. It should be possible to take them out, lay the wiring and replace them.
Juan
Hello,
Juan
Cool, thanks.
How about the rear heater? The wires appear to go UP into the B pillar... where do they go from there? I can't feel/see them in the channel above the door.
Hello,
If I remember correctly, there is a harness that comes from the lower right/passenger door sill into the space between the front seats.
There is provision for the parking brake, the seat belt warning light and the heater.
Wiring harnesses go along the lower door sills.
Juan
That doesn't explain the rear heater wire going up into the b-pillar. I guess I'll have to try to trace it.
Yeah, A-pillar on either side is a fish able area, I have stuff running though both
Any tricks to getting all the way through? I've been trying from the top and the bottom on the driver side and I get so so close.
I got it through the a-pillar on the left side, thanks for the encouragement
