Wire ends to 90980-11140 connector - for Windshield diverter valve
Bean Station, TN
Good day. A squirrel got into my engine and ate his or her way through the wires that actuate the windshield washer diverter valve. I have a diverter valve and a new grey connector arriving soon, but the brown wire ends that go into the male connector are not reusable. Anyone know the part number? Pic here to show connector.
Do you mean the metal terminals inside the connector housing or the rubber seals on the rear of the connector housings? Neither are available from Toyota. However,
Ballenger has terminals:
I'd recommend the terminal crimper, it's a single use tool, but you'll use it again, if you own a Land Cruiser. IMO, it's well worth the investment, because if you fail to get the terminal crimped properly, the connection will fail, sooner or later, and then you'll spend a while trying to find the fault.
and seals:
FWIW, Ballenger can put a kit together with connector housings, terminals and seals for significantly less than you can get the housing alone, from most other vendors.
