Winter projects
Montgomery Co. TEXAS
Now that it's getting cold and the Daylight Savings Run has come and gone...... What's on yer list things to fix, built or modify?
FJ60 rear axle, PolyPerformance 4340's
flip rear springs to move the axle back DONE
Longer rear shocks
IFS kit on front axle, new shock hoods, longer shocks
Notch the NWMP gas tank to fit the new rear axle location
Cut floorboard to raise the tranny/xfer
Build a HD skid plate (my rig and I both need a tummy tuck :rolleyes: )
New wiring harness
recessed taillights
build up my spare parts inventory
Emporia, KS
Need to do:
- properly wire in stereo
- recover and install sammy seat w/ belts
- family roll cage
- straighten/beef up tie rod
Like to do:
- TBI
- York compressor
- larger alternator & Mobi-arc install
Throw in the new baby, mini-truck projects, and saving for Rubithon and I'll be lucky to get the need-to-do items done.
Kansas!
need to.....complete wiring
paint interior/exterior
install gas tank
install seats
those items make jakes 40 complete..than on to the extras
power steering
front disks
4" lift
that should keep me busy....even if i finish all that i still have the 55 to get busy on.....i dont think winter will be long enough...!
be prepared fellas...the questions will flow :D
thanks
osagecruiser
Shawnee, KS
85 4Runner
Everything!
Install 4" lift
Install crossover steering
install gears and lockers
clean up frame, wled in a plate or two and POR-15
Strip interior, patch holes and seal interior
Replace timing chain and get engine running
Complete brake system overhaul
Front & Rear Bumpers
And who knows what else I will uncover.
Irving, TX
Mini Truck
5.29 gears
Hi-pinion front diff
2nd t-case
rebuild tranny
clutch?
header
bigger tires :D
sliders
rear bumper
80
install electric A/C condensor fan
additional power outlets
reroute tailpipe
tornadoalleycruiser
KC Mo
WOW.. My list? Umm
Death wobble fix for starters..
New seats something suspension style,
Full cage with integrated full family bikini top.
Fix tire rack
hydroassist steering
front hood saver hoop of some sorts
TBI? Gotta order some flashing equipment I guess.
Get rid of the Fj62 and start on the FJ45!
Kansas
Change right door.
Repair holes in soft top.
Replace zipper, right side, rear winder.
Check trans, tranfer, axles for wader contamination.
Rust repairs.
Oh, an warsh it....
Topeka,KS
The wish list is toooo long
Front bumper
Rear bumper
hood protecter
winch mount F or B or both
Second batt.
MORE AMPS
more spare parts
AND ON AND ON
Kansas!
hey mike
if did'nt have many pics of your cruiser before this past weekend you sure do now....and some really sweet ones.....but hey...you DID NOT GO IN THE MUD HOLE!...... :D
Topeka, Kansas
With 3 of us having scraped out mud from being high centered, he surely would have made it through. Eric, how long did it take to get your rig washed. Kirk, thanks for posting more pic's. Your 1/2 cab really takes good pictures.
kc_chevota
Kansas city MO
40
fix knuckle
hydro assist
arb in rear
start a spare parts box
mini
new alternator
tube doors
winch mount
new spare tire mount
different seat belts
wheel spacers (wider is better)
arb in front
air supply
bus
new motor
generator
paint job
that should keep me busy for a week or 2 I'll think of somthing after that
Kansas
Don.. ya got a spare door or need more?
Yea I am gonna put the other 73 door back on the right side of mine. But, I need to start leavin my doors behind afore goin wheelin. Soft top too...........
Wheel hard then go home!
tornadoalleycruiser
KC Mo
Don that pic above can be used as an avatar I belive.. Probably about the right size..
Clean my truck? Shoot.. It's locked up at Eric's place right now in his barn.. I guess I can go clean it later this season.. but i'm booked till after turkey day right now so it's just gonna sit and wait. Accumulate parts and rebuild..
Eric's truck needs more attention then mine! His is still just a frame!
Don, some weekend yur NOT wheel'n call me, we'll get ya an avatar.
Crap, my list just got longer... since I had the 40 rear axle apart I decided I'd start get'n ready for the spring flip. Then I remembered the FJ60 axle in the parts pile for Becca's rig..... after a quick call to Erik I talked myself into prepping and mocking up the 60 axle to go in my 40 :D
"Slippery Slip" I think was the term used when I started going bigger....crap!
:beer:
