Windshield Frame Question?
I have a 73 Fj40. I was preparing to replace the glass when I noticed the frame looked slightly askew (sp).
I ran a 4' level accross the bottom of the channel. It was straight as could be. When I ran it accross the top it was in about 1/4" or so in the middle. It is even in the area that appeares to bowed in however.
I'm assuming that the frame is bent, am I correct in this assumption?
Is this a common occurence?
Thanks for the help as always, ROB
Check to see if there's a twist in the frame Eye down one side rail to see if it lines up with the other rail. I had a twist in mine and at the angle of the windsheild if it's twisted the top rail would be out of level. I pulled my glass and twisted it back and it's back to good.
Kevin
