Window Rocket - who’s tried it?
8 months post-install and I've noticed the windows have started slowing down again. AGM battery is good, new alternator, etc.
Time to install a window rocket rocket.
You are welcome to email through the website and I can help troubleshoot.
Just as a preliminary, check if the windows speed back up with the engine running. If so it could be a battery issue.
It appears to be a 12V to 15V 30A DC to DC Step Up Regulator: Example $65.54
The extra $229 is for the bracket, relay, and relay extension.
Amps will stay the same, but voltage increases by a couple of volts = increased power. P = VI.
The moonroof is also powered by the Power Relay.
I mean, you could just install that Step Up Regulator earlier in the 30A FL POWER circuit, but other things will see the added voltage like the seat motors and door locks.
I honestly doubt a few extra volts will be an issue.
I mean, I might install it right at the battery for the 30A FL POWER circuit...
NeverFinis,
Did you try making your own, or has anyone else? I'm worried that the 15V will actually be closer to 16V or more when it gets to 14V with the car running.
Has anyone checked the voltage that the window rocket unit puts out? The product seems worth the purchase, especially with the ease of installation, but I have my own 80 plus my 2 sons' so that is about $800, and I think it could make for a fun project with the boys.
NeverFinis,
I've made a few of them.
A couple things I'd like to mention-
The voltage booster module things you can buy online are made as cheaply as possible. The capacitors are the lowest quality and last 5 years tops. The boards inside are all generic, they use the same undersize traces for all configurations they sell.
The modules we buy for the Window Rocket are specially made for us. They do not function the same as any off the shelf module for starters, and they're made with premium components, oversize traces and conductors and are built to last 20+ years. My minimum order quantity is 300 units and they aren't much cheaper than retail price on the cheap junk modules when built with the right parts. It took a lot of work to figure out who can actually make the quality stuff I can trust and build a product around.
So realize you aren't going to get the same result. You won't get the same quality or performance, you wont get a clean install, you wont get any warranty or tech support. I am all for DIY, especially getting your kids involved. Good luck with your project.
NeverFinis,
No, I bought one. I figured my time was more valuable working on something else. I am multiple projects behind on my LX450...
I don't have the same concerns as PIP as far as reliability as loads are intermittent. Even if it does have issues, buy another brand...
The circuit is fused at 30 Amps, so one should buying something rated for at least 30A, or your booster converter becomes the fuse.
Something like DC DC 12V to 15V 30A Step-up Module, Boost Converter should work, but then you would have to mount it, wire it in, etc..
Just easier to buy PIP's version....😉
Thanks, NeverFinis! I'd buy one too if I only needed one. I'm going to try a 12V to 13.8V, 30A converter first. If that doesn't do the trick, I'll bump it up to 15V.
PIP, your product and installation look very nice. I'll be sure to use some baling wire or duct tape for the install if that makes you feel better!
Because I always complete my projects full hazard, not haphazard.
I think you are going to need more voltage...
I just backprobed position 2 of the Power Relay socket and I got 18.87V. 😬 Probably a 12V - 19V Boost Converter.
It didn't even voltage sag when I tried the window..
Wow, that is a lot higher than I would have expected. On the other hand, I was watching 4WD 24/7 the other day. They have a new guy, and he was driving the rough 60 Series and using an 18V drill battery to roll the windows up and down. It was super fast until the regulator broke.😂 I guess I was all worried about nothing. This information is very helpful. Thank you NeverFinis!!!
