nuclearlemon said:if you go 78, you have to move the w/s rests on the hood. i might have a set of early ones...i know i have one complete one, but it needs the old pin out of it and a new one in (been cut in half by po). pretty sure i have at least one more down stairs. i'll check this weekend.
if yours was factory hardtop the hood won't have any holes drilled for the holddowns, so you can mount them where ever you want, so you don't have to worry about oem holes not being in the right place. be sure to check your wiper arm clearance though...they might contact the hood.offrd63 said:So my 63 was manufactured in 62. Will the 78 hinge work with it? My window wasn't ever a fold down. I need to fing the w/s rests and tie downs also.
aw
i do have one complete, but frozen early hinge (will need to be heated, then worked back and forth until it loosens) and the one hinge that needs the pin. !$12 shipped if you want em.nuclearlemon said:if you go 78, you have to move the w/s rests on the hood. i might have a set of early ones...i know i have one complete one, but it needs the old pin out of it and a new one in (been cut in half by po). pretty sure i have at least one more down stairs. i'll check this weekend.
nuclearlemon said:i do have one complete, but frozen early hinge (will need to be heated, then worked back and forth until it loosens) and the one hinge that needs the pin. !$12 shipped if you want em.
65swb45 said:Alec, the w/s hinge pins are the same as the door hinge pins, so you can buy new ones most places for 2.50ish per. The early w/s rubber bumpers are flat, unlike the stepped ones CCOT sells. I have the 63 vintage bumpers, NOS.
That said, if your hood really has no holes in it currently, you might as well buy the 75 and newer setup because otherwise your w/s hooks will have nowhere to rest when they're not holding your windshield down unless you go thru the trouble to get those little triangular tabs the early hoods had.
