- Thread starter
- #21
Get good tyres. Go trekking with someone else who has a winch. Best of both worlds!
That’s my philosophy on owning a boat.
If you want to attempt to minimize vehicle damage induced by that “urge” that we all experience when we’re out there then winch and armor before tires, lift and lockers.
We get caught up in the moment high on fresh air, peer pressure and the innate need to go farther and that’s when vehicle damage begins to appear, not that I’m anti damage.
We never know where we can go until we try.Vehicle damage is generally the result of poor decision making. (Sometimes things unforeseen, but usually poor decision making).
Rock-crawlers the possible exception, but vehicle damage there....just comes with the territory.
No matter how armored, lifted or otherwise equipped, you can always push things too far. We can call it by different names (Exuberance, Adventure, Spirit, Urges, Caught up), but its poor decision making most of the time.
It is well to know where your rig will (and won't) go and the limitations of the driver (who can be the deciding factor).
The 80 series is indeed an exceptionally capable vehicle in stock form, but still requires the driver know what He/She is getting into.
If there is no 'bottom' in that mud hole that looks so 'tempting'......., well we all how that is going to turn out.
Wheels seem like a good idea so that I can keep my good-condition original LX wheels with my good-condition Michelins for running up and down the road during the week (200-250miles weekly) and quickly swap over to weekend-warrior mode.Why do you want wheels too? Your stock wheels are just fine and a solid 33” tire will get you out and about.
Save the money not buying wheels to buy both a winch and tires.
My opinion will differ from what you’re doing but if you’re only looking at spending approx $100 for beat around wheels then I get the reason.Wheels seem like a good idea so that I can keep my good-condition original LX wheels with my good-condition Michelins for running up and down the road during the week (200-250miles weekly) and quickly swap over to weekend-warrior mode.
Thoughts? I found some Tacoma steel OEM wheels for $100 on FB marketplace.
Just part of the evolution I reckon. Sliders are really the best part of the pending goodies.Why do you need an aftermarket front bumper? Lift, tires, CDL and don't go out alone and you're good for 99% of situations.
“A good man knows his limitation”. - Inspector Harry CallahanWell....I would argue that the prudent man would use good judgement and maybe even glean something from what OTHER'S have done (or not done) before just 'going for it'.
Your point is well taken, that the limits of the driver and vehicle (combination) can be 'explored' but there is a high end to that if you want to avoid expensive lessons.
I mean....I'm not absolutely sure I can't fly, but I'm not going to dive off a cliff to find out. I have noted that others can not fly (unassisted). I'm fairly certain gravity will work upon me...the same way as others, but 'until we try' I can't say for sure.
Building a vehicle for off road adventure and then actually using it isn’t prudent according to many in the first place.
Have I ever equipped a 4x4 in the manner which I suggested here in my first post? Absolutely not. I was merely bringing forth a concept that the OP had yet to read in this thread. Personally, I believe that if your rig isn’t showing some scars at 20 years old plus, then it hasn’t really been off road.
I will, however, stand by this remark. Buy differential lockers and gears to match the tires and lift that you put on all at the same time. I’m all for lift and larger tires but open diffs make it difficult to keep our desired trajectory in true “off road” situations. And if a guy is planning to settle for a cheap chinese winch he might as well through that extra $300 at the same time.
Man, you must have REALLY botched that rapid run. Personally, I've done plenty of questionable things after 3:30...I think one time I even made a bad decision at 4:00. A whole thirty minutes past. What can I say? I like life on the edgeI always chuckle when I see the phrase 'just throw the 35s on..."
In my 25 years of 'wheeling, I've come across very, very few people who would be physically able to do that...
Personally, it has taken me a long time of running trails before I thought it would be good to have a winch. I've done the bigger tires thing first, then lockers shortly after that. And as for getting stuck, there are two things that helped me quite a bit:
1. Looking at every obstacle, I've very early on started to ask the question 'even if I make it, can I drive this thing the other direction in case I have to turn back??" That then morphed into 'Being too proud to turn around is simply stupid (particularly if I'm by myself...)' - there were always plenty of other trails to run.
2. The "3:30" rule - nothing crazy/questionable after 3:30pm. The rule came initially from a canoe trip and a botched rapid run, but translated easily into 'wheeling, and has served us really well. I'd even say that the "3:30 rule" is better than a winch. Much cheaper, too.
