- Joined
- Aug 30, 2019
- Threads
- 47
- Messages
- 194
- Location
- Wilsonville, Oregon
- Website
- ironman4x4america.com
- Location
- United States
Nitro Gas 2" Lift Kit- $799 down from $1,375
- NITROGEN GAS PRESSURIZED - Low pressure nitrogen gas dramatically reduces the likelihood of oil aeration and shock fade.
- 35mm TEFLON BANDED PISTON - Precision shim-stack piston specifically valved by Ironman suspension engineers, banded with teflon for smooth long life operation.
- 54mm TWIN TUBE BODY - Increased oil volume for improved cooling and endurance, Twin tube construction protects internal components from rock damage.
- 16mm – 18mm HARD CHROME PISTON ROD - Hardened and polished, volumetrically balanced to piston size.
- FLEXIBLE RUBBER BUSHES - Offers quieter operation and reduces damaging side loads from shock absorber.
- TRIPLE-LIP HIGH PRESSURE NOK SEAL - Maximum gas and oil retention ability to withstand high displacement offroad use.
- SUPPLEMENTARY WELDED MOUNTS - Fusion welded and supplementary welded for maximum strength and reliability.
- SINGLE PIECE BILLET EYE RINGS AND STEMS - Ultra robust design prevents breakage or bending of mounts.
- VEHICLE SPECIFIC VALVING - Every part number is specially valved for each vehicle application, this ensures the best possible ride and handling as intended by Ironman suspension engineers.
- LONG TRAVEL - Suitable for standard and raised height vehicles, additional length increases wheel articulation.
- IMPACT RESISTANT STONE SHIELD - Steel or Polyethylene dust shield protects piston rod from impacts and road debris.
3rd Gen Tacoma with 2" Foam Cell Pro Ironman 4x4 Lift Kit
"Mt. Hood" edition Tacoma at Toyota of Portland with our 2" Foam Cell Pro Lift Kit
