Stroker SB with cam to reach max torque at 3400 rpm.
Bandy has got it right. (can't believe that I just said that)bandy rooster said:the only thing that would be stopping you, is your own ability.... not knowing what you can do; your the only one to answer this then... then you have to start working out kinks... is the 208 centered or offset? if its centered you could run the lc/mini centered hybrid axle... and so on and so forth
