well, I suppose the easy answer is no if it doesn't get into the combustion chambers. On the other hand, if you put it in the crankcase it is presumably to clean things up, so assuming that it works well (not obvious), it would start to loosen things up, both making crud more movable and opening up clogged passages. At that point you may well have more engine oil (and seafoam) make its way to the cylinders and perhaps generate more smoke.
Having said that, would you likely see a big could of smoke come out the next time you fire the engine up? I don't think so...
