Will OME 861/862 with N70/N71e installed "break in"? (1 Viewer)
San Jose, Costa Rica
Greetings from Costa Rica.
Last week I finally had the matching N70/N71e shocks installed to go with my 861/862 springs on my '94 daily driver. To my dismay the truck still rides very firmly/jarring on bad pavement, :bounce: which is everywhere down here. It does flex nicely, though.
Before the Emu shocks I had installed new factory Toyota Tokico ones. They felt nice at first, but after a couple of months they got harsh, too. :bounce2:
Will the Emu shocks/springs "break in" and soften up some? Would replacing the Emu poly shock bushings with new OEM rubber ones help?
My tires are 245/70/16 poor quality 2 ply sidewall with street tread and inflated to 29 PSI. Maybe taller/wider new AT tires would help?
Any thoughts?
Tapage
Club 4X4 Panamá
Panamá
I don't think OME spring rate or shocks valving will vary ( decrease ) with time ..
Bend, Oregon
Any idea if they are riding harsh because you are bottoming out the suspension while driving or because the shocks have too much compression dampning? I am not sure at all how the 70/71 shocks compare to the 73/74 shocks in terms of valving.
crikeymike
Exit Offroad - Dobinsons Specialist
Supporting Vendor
Jacksonville, Florida
You've got the softest valved shocks that were ever offered.
How many miles are on your truck? Maybe it's such a drastic change, and it feels "like it should" to a lot of other people, but you're just not used to the change? I've got 850/863's with N73/N74E shocks and I wouldn't call it harsh at all.
SW Michigan
I swapped some Iron Man 2" front coils into my rig (formerly your same setup) and the ride comfort improved greatly plus I gained a level lift stance. It was a win/win.
Dan2722
San Diego
FWIW when I went from the 861/862 lift to the 850/863 lift my rig rode much better. I had the 861/862 on for about 3 years and it always seemd a little harsh on rough roads.
Putting some larger tires under yours should help.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
