I know a guy who is selling his 4" rough country lift kit off of his 76 FJ40 at a very reasonable rate. Does anyone know if these will fit on an 81 BJ42? Thanks in advance
The shackle and fixed pin outer diameter changed in August 1980. Old Man Emu (OME) dealt with this issue by making the bushing holes in the springs larger than stock, and offering two different bushing models to back the different pin sizes.
You could potentially make those Rough Country springs work on the BJ42 by switching to bushings that accept the larger diameter pins.
Just to summerise the situation from my perspective:
81 BJ42 has 35mm internal diameter spring eyes and larger diameter fixed-pins and shackle-pins (18mm I think)
76 FJ40 has 25mm (1 inch) internal diameter sping eyes and smaller diameter fixed-pins and shackle-pins (15mm I think)
If you want to fit the 76 springs to the 81 - You'll need to find bushes for the spring-eyes having only about 3mm wall thickness (difference between ID and OD) - which IMO is way too thin for them to do their job properly (even assuming you can get/make them). And you'd also be left with the undesirable situation of having your spring eye bushes different from the "standard 81" bushes you'd be using in your "chassis tubes".
I've though about this before - when I was going to go the opposite way -- Fitting later model springs to my earlier model cruiser. (And I decided against that too.)
If the springs were made in the last 15 years they probably have the larger eyes. ARB, skyjacker, HFS
spector, man-a-fre and every spring I've seen use the 1 3/8" or 35mm eyelet.
We don't get many BJ42's in the states but I know those springs will fit FJ40's until the end of their production. I can't say for the other vendors but man-a-fre's bushing # is 2033
