Wife's rack is sloppy
Discussion in '100-Series Cruisers' started by 4FLATS, Nov 27, 2017.
  1. PabloCruise
    PabloCruise
    16,451
    1,362
    Jun 3, 2004
    Northern Colorado
    And I think reman items are required to say so in the description...
    TXLX100 likes this.
  2. PabloCruise
    PabloCruise
    16,451
    1,362
    Jun 3, 2004
    Northern Colorado
    How many miles on her rack? Make sure it is not leaking. If it is, I would replace...
  3. TXLX100
    TXLX100 Supporting Vendor
    2,471
    361
    Feb 9, 2013
    Fort Worth, TX
    Usually the reman parts end with -84
  4. TXLX100
    2,471
    361
    Feb 9, 2013
    Fort Worth, TX
    I guess so, I really wanted to buy one from them but having truck down 3-5 days even at a shop is too long. I'll buy their CVs though.
  5. joshAUST
    joshAUST
    63
    34
    Jul 11, 2017
    Hobart, Tasmania, Australia
    I had a leaking rack, and no OEM ones available, so I went with aftermarket, for around $700 AUD.
    I kept the original rack though, as I thought I'd prefer to get the original OEM one rebuilt rather than buying another aftermarket one, if this one fails.
    I've read a few reports of aftermarket ones failing, hence why I kept my OEM, but its hard to say if all the aftermarket ones, or just specific ones, have issues.
    I'd do the same, go aftermarket, but keep your presumably OEM one to rebuild at some later point.
  6. 4FLATS
    4FLATS
    88
    10
    Jun 15, 2010
    Well, Inner rod ends are pricey! Looking at $500 for the set vs $745 for a new rack with inner included.
    Argh..
  7. bamabrock
    bamabrock Ain’t Life Grand SILVER Star
    2,109
    509
    Jan 22, 2010
    Birmingham, AL
    Cruiser Outfitters
    100 Series Tie Rod End Kit - $187.50 (Now in Stock!)
    Japanese 555 Brand - Made in Japan
    Complete 4 piece kit w/OEM Toyota Jam Nuts
    Fits 1/98-7/2002 IFS 100 Series Land Cruiser & Lexus LX470
    Part# TRE100ETRE
    Fits 8/2002-2007 IFS 100 Series Land Cruiser & Lexus LX470
    Part# TRE100LTRE
    100 Series (1/1998-7/2002 IFS Models) Individual Ends
    RH Outer Tie Rod End - Part# TRE4669195 - $37.50/each
    RH Outer Tie Rod End - Part# TRE4669195OEM - $72.50/each (OEM Toyota)
    LH Outer Tie Rod End - Part# TRE4769100 - $37.50/each
    LH Outer Tie Rod End - Part# TRE4769100OEM - $72.50/each (OEM Toyota)
    LH/RH Inner Steering Rack End - Part# TRE0369015 - $62.50/each
    100 Series (8/2002-2007 Models) Individual Ends
    RH Outer Tie Rod End - Part# TRE4669205 - $37.50/each
    LH Outer Tie Rod End - Part# TRE4769115 - $37.50/each
    LH/RH Inner Steering Rack End - Part# TRE0369025 - $62.50/each
    DirtDawg likes this.
  8. KiteOregon
    KiteOregon
    33
    Media:
    1
    Albums:
    1
    7
    Feb 14, 2017
    Portland, OR
    I second Cruiser Outfitters, just completed this job. Kurt is great to work with. Quality is top notch.
  9. 4FLATS
    4FLATS
    88
    10
    Jun 15, 2010
    So I found the smoking gun. Inner tie rod end had a lot of play, Replaced inner and outer on drivers side. Passenger side seemed tight.
  10. PabloCruise
    PabloCruise
    16,451
    1,362
    Jun 3, 2004
    Northern Colorado
    How difficult was it to replace inners?
    Wife's rack is not leaky, is it?
  11. 4FLATS
    4FLATS
    88
    10
    Jun 15, 2010
    Inners are cake with the correct tool. This was the first time I had ever done tie rods and I kinda feel stupid for being afraid of it now.
    I got the 555 brand from NAPA but their tool didn't fit. Oriley's Auto parts had the correct tool and I could do the job in 2 beers if I had to do it again.
    PabloCruise and UltraFJ40 like this.
  12. SteveY
    SteveY
    71
    Media:
    27
    34
    Oct 23, 2016
    Cincinnati
    I'll second this. With the correct tool, it is a piece of cake. Here is what I used:
    OEMTOOLS 27178 Master Inner Tie Rod Tool Set https://www.amazon.com/dp/B01MS7FD62/ref=cm_sw_r_cp_apa_dpIwAbD27THFV
  13. ranma21
    ranma21 SILVER Star
    2,425
    284
    Apr 18, 2005
    Houston, TX
    Good to hear that. So which Oriley's tool did you use?
  14. 4FLATS
    4FLATS
    88
    10
    Jun 15, 2010
    The big green pipe with all the keys, NOT the Everest one with only 3 sizes.
    Then over to the Firestone dealer for an alignment. I popped for the lifetime alignments for basically the cost of 2 alignments. I have CV service coming up and figured why not. Also they will align it if I end up with a lift kit. Most shops shy away from that.
