Why would TOYOTA Disc. / NLA 1964-1984 FJ40 FJ55 Slave Cylinder Mounting Bolts Anyway ? no matter i made them alive and better once again ! (1 Viewer)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
No matter , i made them alive and better once again for us .....:cool:
#8 mark head , Double SEMS Hashers , SILVER BLUE Violet highest salt spray rating plating
- TOYOTA oem ones were only JIS mark head
#5 .....Please :rolleyes:
- 100% Made in japan Spec. parts , i special spec'd ordered to Factory Fit Form Function , and over-preform in all the right places
well it does NOT matter anymore ...... :D
- 91111-41056
- 91111-41055
- 91611-41055
1962-10/85 FJ55 FJ40
3 speed , 4speed , 5speed
JIS #8 mark head
double SEMS washers
Truly
SNOW VERSION bolts in every way
Silver Blue violet plated highest salt spray rated plating !
100% Made in JAPAN spec.
Have you heard the joke about bolts. If it goes on your car it's ten cents, if it goes on your airplane it's a buck and if it goes on your helicopter it's ten bucks. :)
Have you heard the joke that any of my made in Japan spec. reproduction task and detail specific assembly hardware that TOYOTA disc. / NLA . and or still offers 1972 APOLLO Moon Program Era Technology Plating and Shear Strength , like the Thermostat Housings kit ........
Is not available at your local ACE Hardware HOME DEPOT you have in little brown paper bags right now as we speak .. :idea:
Oh and if that same bolt goes on a satellite then its $100.
I wasn't complaining, just trying for some levity. People are lucky that you provide products that are unobtanium - those look like very nice bolts.
I know you were using and applying same in kind my usual satire and dry humor good will intended to keep it lite at all times OEM JIS communication approach ….😎
I whipped out that “ giving it my TEq-2-Cents “ Technical Image above a good while ago..
I only used It one time as I recall long ago …?
It was an instant TEq-Parts-Jedi Mind-Trick-Approach opportunity to apply it and observe the Laboratory tech spec. data …
The below one , is an actual intact first ever my local TOYOTA dealership Parts Department I worked M-Thurs after skool in 10th grade
It was a big thing to be handed these by your Parts Manager at the time …
the Common Toyota Dealer Parts Dim-Wits that wore a new and different Black Heavy Metal T-Shirt every single day to work 5 days a week all had to fight over the one Zip-Tied to each parts counter long leash style missing a cover and other pages too …
Those of us who actually owned a toyota car or truck and had any level of interest in there daily job of a Swivel Parts stool and a microfiche viewing box 📦 at there work station that was far bigger then any TV set at the time I ever saw anyway …
Dare NOT forget to put the coveted paper print media nomenclature fast movers in your EMS back pack at the end of your day …
If you got sloppy one time …and spaced it on your work station or in your metal file cabinet drawer ?
The “Twisted-TEq-Parts-Dept. “ Sister Marlboro Hard-Pack box “ Dims “ would find it H55F fast and you no longer had your own special “ thing “ any longer till the next years publication was published and handed out again ……😕
The initial spark ⚡️ pipe dream of finding better T-stat housings sandwich M8 and block face M10 Hardware came from simple frustration of snapping one or more sandwich M8 ones became a normal thing ?
And
It hitting me one frozen day out working when the County Schools were closed due to a ice storm , Cheeze- Ball JIS a mark head #5 single SEMS lock washer only Getto-Grade odd flat silver coated hot dipped galvanized M10’s. …
Were in-fact causing one of the lower housings “ ears “ to snap off upon the most carefully star sequencing removable by hand attempt
Below are your OEM JIS Interstellar Japan Spec. bolts TSB you requested
thanks
