Why won't me fuel guage work ?
courtesy desk
Just replaced the fuel tank with a poly. Also replaced sending unit. Fuel
Guage won't work now. Put in old sending unit and this also is not working .
Everything was working fine before I replaced the tank.
Ideas appreciated
Paul
SE Iowa
Mine gave me fits until I ran a ground to the engine bay, effectively direct to the battery. Wouldn't take too long to try, mught be worth a shot. Other than that, I don't know. I, too have a poly tank, but the original sender was not hooked up, so I don't know if it would have worked or not.
Tony
courtesy desk
Tony
Tony .. I tried that and still not go. Thanks for the idea tho.
Paul
Cedar Rapids, Ia
You have to ground it to the sending unit. The meter in your dash reads the difference between your varible resistor in your sending unit and its ground. I played it safe and went from sending unit to chassie ground to gage. Just to prevent any static electricity.
courtesy desk
Thanks ... makes sense. I'll give it a go and report.
Much appreciated Duds :)
Paul
