I have an ARB duo compressor mounted under the hood. It was installed by Slee (with their bracket) on my 2016. When I traded in the 2016 for the 2021 HE in May I had the tech at the dealership transfer it to the new LC. Worked great until a couple weeks ago when it just died. Took it into the shop today and it found that the two rather large fuses had blown. They replaced the fuses and it appears to be working. They inspected the wiring and don't see anything that is worn or exposed. But something made those fuses blow.
I use my compressor a few times a month at the most but mainly just to top off my KO2 tires or the tires on our trailer. (Add a couple PSI to each tire.) I haven't done any air down/up yet this year. I also use it to "inflate" the airbags which takes about 5 secs.
Any ideas what I should inspect to ensure I don't have a problem lurking? What is the life expectancy of these compressors?
