Trevor said:Uh...That doesn't look like '77 distributor. Is it possible the PO swapped in a Chevy distributor? I don't know much about the swap, but I know they are compatible. It kinda looks like the condensor is under the rotor in the photo. This would replace the igniter on the fender. One of the old timers on this board should be able to give you more info about it.
Dianna said:Thanks Romer, you're awesome! I sent you a PM. Thanks for all the help guys, glad I posted this before it screwed up my motor... doesn't everyone just LOVE p.o.'s??? Landpimp, it does have headers but still has the original carb. I saw on here when I did a search a few days ago that someone suggested a dizzy from a '78 or newer but thought that the carb might need to have a port drilled in it for vacuum advance, is this correct?
