DO all diesels have oil fed alternators, or is this just a 3B thing, what are the pros of it? was just wondering for I have never seen that before on non diesel motors?
Thanks
Rob
Thanks
Rob
.....diesel engines do not produce the vacuum that a gasser does......
I've always wondered about this. (Our diesel engines have pistons, valves, and intake-butterfly-valves - just like their petrol cousins.)
Maybe it has more to do with the fact that intake manifold vacuum plays such a vital role in moving the diaphragms and racks within our injector pumps.
So using intake manifold vacuum for a brake booster would mean "touching the brake pedal" would tend to "increase engine rpm/power" (by dumping more fuel in each cylinder) - particularly at low engine rpm.
Thoughts?
The air intake on a diesel is not throttled in the same way as on a petrol engine.The inlet manifold is open to atmospheric pressure (not counting the extra boost of a turbo).Even on engine overun with your foot off the throttle pedal there is no restriction of the air flow into the engine so it cannot build a vacuum on the inlet side sufficient to operate a brake servo.The throttle on a petrol engine meters both the air and the fuel.On a diesel you're just controlling the fuel input.
I guess you're supposition in your first post that using manifold vacuum to power a brake servo would interfere with the vacuum controlled fuelling must be the only answer.From the setup you describe,a sudden decrease in vacuum from hitting the brakes would certainly make the pump 'think' you're on the accelerator and deliver more fuel/power.
Not quite. The difference between manifold vacuum and this venturi vacuum is the volume of air it can move. Sure, the venturi vacuum on our diesels gives a pretty good "suck", but its sucking against a dead end, the diaphragm. Even when the diaphragm moves the volume is pretty small so the venturi doesn't have to suck out much air to build up vacuum.
Manifold vacuum, on the other hand, has the entire volume of the engine itself pulling air behind it - for a 2F, for example, each stroke pulls more than a liter of air! Thats far, far more volume than the venturi is capable of.
The problem, then, is that if you've been cruising on the highway (low vacuum) and slam on the brakes, the venturi would have to suck all of the air out of the booster. Boosters are big, and the venturi is a small hole... it'd take several seconds for boost to build up.
This is also the reason why there is a vacuum reservoir, even with the vacuum pump.
