"trimmed rad mount/rear 1/4's " What does this mean?
If you look at the head on picture of my van youll notice that it has a pretty low profile front bumper. The lower rad mount (the part that is in front of the tire and attached to the inner fender/front body mount) used to hang low and it bugged me so I cut a triangle out of it, folded it up, and welded it back together. Dont really know if it did anything to clear the tires since I had 285's on there when I did it.
When you look at the picture of the rear end of the van you can see where I cut the rear 1/4 pannel at an angle and the low profile bumper. Again this was done before the 37's were on not out of necessity.
We don't have winter, so I'm not worried about that.
Will 5" back spacing create more rubbing or improve my chances of not rubbing?
In my experience, the KM2's were softer than what I wanted but a good trail tire with thin side walls
Soft compound yes, they don't have the longest mileage life plus they chunk from playing in the rocks.
Thin side walls? As in weak? This is the first I've heard of that. I've had a gash in 2 of my tires for almost a year with no issues.
The only knock I've heard of on these tires is the snow and ice performance. It sounds like weather isn't an issue for you.
I have 345's on stock wheels with a 4 inch suspension lift, 1" body lift, 1" wheel spacers, landtank's LCA's and stock bump stops. The front doesn't rub at all, but the rear rubs like crazy at full articulation.
I would worry about the rear more so than the front. You might think about going with a taller spring for the rear.
