So I've got this shake in the truck between the speeds of 59-64 mph, approx. To me, it feels like it's coming from the front end, but it shakes the whole truck, so I could be wrong on that. If I accelerate and I'm going uphill, sometimes it doesn't shake. It seems to settle down after a while, but if I hit a bump in the road, it starts all over again.
At first I figured the tires were out of balance, or it was the typical "old BFG AT" problem that causes vibrations when they wear out. Replaced the tires all the way around 3 weeks ago, still have the shakin'.
Moved on to the U joints. I did a full chasis lube about two weeks ago and the U joints were non-greaseable, so that was out, but the drive shaft yoke was bone dry and I felt a little movement there...filled it up with grease and the movement was gone, and there was no movement in the U joints that I could feel.
So now I'm at a loss, but I have found a few things that were failing underneath and I'm wondering if these could cause the problem:
1) Added grease this weekend to the knuckles and checked the play in the front bearings, they were good.
2) Front pass side shock is bleeding/failing, probably shot.
3) There's a leak somewhere that is causing fluid to leak over/around the visible area of the steering box in the inside driver's fender well. I don't know if it's the steering box leaking, or if something else is leaking on it that that's the drain path.
4) off the path, but the rear pass axle seal is blown and when it gets good and hot, it throws grease out of it. Doesn't leak bad, but it's been going for a while. I don't think there's any play in that wheel though.
So, any thoughts on this?
were worn on the pass side. I did a little Southern engineering and shimmed it up temporarily. Shake is gone, and now I get to buy some cool new parts for the truck. Gotta do it right, right?
