91-2 will need a diiferent pedal, just get one out of a 93+, it's then all bolt on. 93+ has the correct pedal already.
last US spec Cruiser that had the hand trottle was the fj62, for some reason the 62 had it but the 60 didn't, early fj40's did, inthe early 1970's the hand trottle was left off
on a 80 i mounts in the hole to the right and down of the steering wheel, then goes to the pedal.
[quote author=Landpimp link=board=2;threadid=6420;start=msg51947#msg51947 date=1066400833]
John
[/quote]
Not all 93's have the correct pedal. It has to look like this on the top.
[quote author=sleeoffroad link=board=2;threadid=6420;start=msg51997#msg51997 date=1066407236]
Jonathan,
Yes, that's the hand throttle. Usually you pull it out to get to the desired rev speed, then turn (quarter turn) it to lock or set it at that position.
Bill
Jonathan,
To use the hand throttle, you first use the accelerator pedal to bring the engine to the desired RPM, pull out the hand throttle to match the RPM, then turn the hand throttle to lock.
-B-
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
