Who Sells Both EGR Block-Off Plates for Both 1981 2F Manifolds ?
Discussion in '40- & 55-Series Tech' started by RAGINGMATT, Jan 13, 2018.
  1. RAGINGMATT
    RAGINGMATT Factory Focus-Point Mind-Set Approch..... Supporting Vendor
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    Hi ,
    I am getting ready to Trim-Out This Fresh-Puppy Below & Need Both the intake #45 & exhaust #1
    ones in diagram below , to Delete them / DE-SMOG ! :poof::poof::poof::poof::poof::poof::poof:
    Posted Links To the right quality Vendor appreciated :cheers:
  2. brian
    brian SILVER Star
    8,821
    2,228
    Feb 7, 2003
    lebanon,pa
    Were are you getting pcv vacuum if you plan to cover no.45?
  3. GA Architect
    GA Architect SILVER Star
    2,578
    4,687
    Feb 14, 2014
    Woodstock, Georgia
  4. 1911
    1911 chupacabra
    4,968
    Media:
    183
    Albums:
    4
    3,627
    Aug 11, 2006
    Parker County, Texas
    What @brian says. Most people leave this fitting on for the PCV, and just plug/weld up the end of the EGR tube that comes out of it.
    The exhaust manifold blank-off plate is sold by Jim C., SOR, MAF, etc.
  5. RAGINGMATT
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    I was planning To utilize Both the threaded Vacuum service Ports on each side of the carb on top side if intake manifold , One For PCV , The other for My brake booster
    I have 2 of these Star Wars Tower vacuum fittings correct size for PCV & Booster hoses
    Is this a bad idea ?
    please see photos below , service ports circled in Red
  6. RAGINGMATT
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    I looked @ SOR they had neither plate unless i missed it ?
    I have seen photos of Jim c 's plate , it has a nipple that goes up inside the exhaust manifold if i recall correctly , what is his member ID to contact him ?
    thanks
  7. Splangy
    Splangy SILVER Star
    6,532
    951
    Aug 4, 2009
    New Hampshire
    Block off plates like this are very simple to make yourself.
  8. RAGINGMATT
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    thanks , I guess i have found @fj40 jim c too......
  9. brian
    brian SILVER Star
    8,821
    2,228
    Feb 7, 2003
    lebanon,pa
    Bad idea.
    One is fine for the booster.
    Pcv coming off anywhere but center of the intake, will lean the cylinders out on the side the pcv is on.
    RAGINGMATT likes this.
  10. RAGINGMATT
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    Right , :popcorn:
    Just Like a First Generation Siamese F has PCV Tube Hose at carb base insulator Smack Dead Center
    Thanks ........
  11. brian
    brian SILVER Star
    8,821
    2,228
    Feb 7, 2003
    lebanon,pa
    could just use an earlier intake as well.
  12. 1911
    1911 chupacabra
    4,968
    Media:
    183
    Albums:
    4
    3,627
    Aug 11, 2006
    hmmm... I thought I bought mine from Spector, but naybe it was Man-A-Fre - it's been some years and I don't remember.
    Jim C. is FJ40Jim here on Mud.
  13. RAGINGMATT
    2,192
    Media:
    21
    1,119
    Aug 12, 2007
    East Coast
    Great many thanks @1911 , I will be reaching out to him . I also valued @brian 's info on the PCV lean out mixture details SPEC. to center the PCV and not block it off & Not use both star wars threaded fittings / ports the way i was planning ..........:popcorn:
