speculate how this happened.
is it as obvious as it looks? bearing not pressed far enough down the shaft, or bearing not seated on the case side all the way, or not pressing the rotor shaft all the way until the bearing sits on the bore lip?
If that's true, then how did I end up with same connecting bolt measurements that hold both haves together. What I didn't do was measure bearing depth on the shaft. I find no spec anywhere on that measurement.
If you press the bearing into the back end case and press the rotor in you run the risk of bottom it out on the fan plate.
The alternator didn't fail, it was just putting out lower and lower. I put in the spare without looking at the slip rings and measuring the new one.
Also, it seems these rings aren't that replaceable. And if you buy a new rotor it doesn't appear to come with the bearing already installed. For this reason alone it doesn't seem logical to buy a new rotor.
Seems like I need practice. or I'm missing something. This should be easy.
