Truck info:
1997 FZJ80
153K mi
I have been having engine troubles lately. It started with EGR Insufficient flow, and then I was having a cylinder misfire at #5. After some searching I was convinced I was having a problem with the wiring harness. I read this post https://forum.ih8mud.com/showthread.php?t=118026&highlight=wire+harness and was having the same problems. So I examined the harness and all was well visually. So while the truck was running I tried moving the harnessw around to see if it would effect anything. nope.
So I wrestled the EGR valve off and cleaned it out. Reassembled and all seemed well. On the second lap around my neighborhood the bad idle came back. And a thick white smoke. I read some posts on white smoke and got convinced it was a blown head gasket.
Onur was over this morning and was poking around it. Before the engine warms up, everything is fine. As it warms up the idle gets worse and the smoke gets thicker. The smoke has a slight blue tint to it and does not smell like coolant. Instead it has a gas smell. We also noticed that at high RPMs there was smoke coming from the manifold side of the engine. There was a fluid dripping from the exhaust manifold. It was real hot (smoking actually) and greasy.
Once the engine cools down I will take off the heat sheilds. Is there anything specific I should look for? A break in the manifold gasket?
1997 FZJ80
153K mi
