White smoke and water from tailpipe
I don't know if this is related to my smog test failure but I noticed when starting cold with the choke on i get white smoke ( like you see on really cold mornings) coming from the tailpipe. It is accompanied by a trickle of water. I push the choke back in and let her warm up a bit and the smoking stops. What would be the likely causes of this? Valve guides and seals are new. Just had the head redone and a new gasket installed. Retorqued after 300 miles. Just changed the oil and it was not contaminated.
Maybe this is normal? I never noticed it before .
Any ideas?
Thanks,
Bob
All I can say is that on cold days ALL vehicles will do this, Im unsure of what engine you have, But I know the FZJ80 does it alot till its warm. I would be more concerned about the smell rather than the look. Running rich would be more black...I think and it would really smell of gas.
Good luck once again :)
Thanks, You're probably right about the vapor . I'm just looking for anything that might keep me from passing my smog retest. It's not black smoke.
The engine is the stock 1978 2F with a whole lot of CA emissions stuff.
Sounds like condensation. No problem. If it continues after the engine is warmed up, then it would indicate a coolant leak into a cylinder(s).
my carbed Cruisers do the same thing in the winter, its nothing to worry about...........unless it doesnt go away
The water that comes out of your tail pipe is also a byproduct of your catalytic converter. So that shouldn't be much of the problem.
Thanks guys, It's been a little colder here in the A.M. lately. I hoped the vapor was normal but I thought I should ask. CA smog goes back to '74 and with the new smog laws it will always be 1974 and earlier that are exempt. That means I have to get my truck smogged every other year for as long as I live in this state. Smart thing to do would be to sell it , but I'm not very smart.
No Catalytic converter on the '78 , I think they first put them in LC's in 1980(?)
NorCalCruzr said:
De-Smog that baby? You are 1 year under the 1979 smog test exemption in Cali.
Just a :idea:
B
they stoped the rolling exemption i think its stuck at 76'
Is that statewide or restricted to those counties within the pervue of either Bay Area Air Quality Management District or Los Angeles Basin AQMD?
If statewide it's not only a huge windfall for the state but an equally huge and unjustifiable hassle for people living in the sest of the state.
