Anyone get this noise and know the solution? It’s coming from behind the dash, sounds like a reed noise (musical reed) and is definitely caused by outside air being forced through something that is likely vibrating to cause noise, like a reed vibrates or if you put a pice of grass between your thumbs and blow. Only happens at 65-75mph range and doesn’t happen when it’s raining. When I had my console apart to install new 6x Tesla screen I took it for a drive to see if I could better locate the exact area of noise but no luck.
