Hi Everyone,
I really need some assistance in identifying and troubleshooting an issue.
When my 105's hubs are engaged I get a whirring sounds which increases in pitch as I gain speed, this occurs in 2h/4h if the hubs are locked. when unlocked the sound isn't there.
I've done the following:
-Replaced the passenger axle + CV
-Pulled the front diff, pulled apart, put back together with crown backlash and pinion flange play within recommended specs.
-Rebuilt both front wheel hubs, new bearings, gaskets, seals.
-Rebuilt both Swivel hubs, new bearings, gaskets, seals & repacked
-Wheel bearing preload within recommended specs.
Could this have anything to do with the hub engagement or the bearing in the freewheel hub?
I was thinking of removing the front drive shaft and locking the hubs to see if the noise continues, will that work?
please and thankyou.
