Whine at highway speeds?
Discussion in '60-Series Wagons' started by adidasprof, Jul 15, 2005.
  1. adidasprof
    adidasprof
    154
    2
    May 25, 2005
    Atlanta
    By whine, I mean a noise and not a drink....anyway, I've noticed my Father-in-law, my brother-in-law and my FJ62's all have a sort of high pitch "whine" while at highway speeds. I thought maybe it was the blower motor something like that, but if you put it in neutral while it's making the noise, it goes away. Anyone have any ideas? I hope I'm making sense on this. Thanks.
  2. tcb
    tcb
    2,775
    Media:
    3
    Albums:
    2
    180
    May 2, 2005
    Swinging from a vine.
    Could it be tire whine? I also developed quite an audible whine when my transmission shop forgot to top of the gear oil in the Transfer Case... but very soon after the whine began, I was pulled over on the side of the road with a fried TC.... So at least check to see if your TC is full of oil. I *believe* I have also heard that the diffs will whine when they are fixing to go as well.... but I may be mistaken.
  3. adidasprof
    adidasprof
    154
    2
    May 25, 2005
    Atlanta
    Thanks TCB, I'm positive that it's not tire whine because if I put it in neutral at highway speeds, the whine goes away, but I'll look at the TC and diff. Any other comments or suggestions?
  4. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    Don't have a 62, but it sounds like its the trans...prolly the torque converter.
  5. flowman
    flowman
    144
    Media:
    28
    Albums:
    1
    Nov 21, 2004
    wishing I was in Briland
    I don't know what's making your in-laws whine ( ;p ), but I've heard the worn idler shaft bearing in the tcase whines when worn, and mine's doing it at 170k...I need to have it rebuilt soon. DD says as long as it shifts from HI to LO you're ok.
  6. adidasprof
    adidasprof
    154
    2
    May 25, 2005
    Atlanta
    Thanks flowman, mine has around 170k on it right now too, but my father-in-laws 62 only has 75k on it. But you don't think it's a pressing issue?
  7. krzyabncanuck
    krzyabncanuck USFS HOTSHOT GOLD Star
    8,717
    735
    Apr 5, 2005
    NC
    I've seen it where the pinion bearings are getting ready to go out they start whinning. Don't ask how i know.
  8. BlueCruiser84
    BlueCruiser84 SILVER Star
    2,869
    907
    Nov 1, 2004
    Staunton, VA
    What do you mean "top it off" can you fill it up more after the fill hole?
  9. tcb
    tcb
    2,775
    Media:
    3
    Albums:
    2
    180
    May 2, 2005
    No, sorry for any confusion.... the shop basically sent me out with a half filled t-case..... and the t-case didn't like it very much.
  10. wingysataday
    wingysataday
    789
    Media:
    1
    184
    May 16, 2005
    Boise
    Mine whines to but all of my fluids are topped off. I can still shift into high and low so check the fluids and see if it shifts then don't worry about it till it makes a clunk sound.
  11. schaats
    schaats
    284
    5
    Apr 3, 2005
    Kyunggi, South Korea
    My FJ62 whines also that I'd checked and thought that it's from T/C rear output bearing.
    So I'd overhauled my T/C but it didn't stop whining.
    After comprehensive research, I finally found that it's from rear diffrential's pinion bearing.
    My FJ62's whining started after 3 hours of high-speed driving on the newly built good highway .(About 140~160 km/h)
  12. ga89hoss
    ga89hoss
    300
    Media:
    2
    277
    Jul 18, 2005
    Atlanta, Georgia
    Hey im only 16 but i bought a 1989 62 and seems like we have the same problem. I was driving to charleston when the whine started and it would stop at about 2500rpms or 70 mph. My problem was a loose belt way down in the engine that i couldent get to on the side of the road. Dont know if that helps but its a start.
