While I'm in there... Suspension/Steering?
TheGrrrrr
GOLD Star
Scottsdale, AZ
I've notice the bushings on the front LCAs and Sway Bar Links are in pretty bad shape so I ordered all new LCAs and links during the big SE Region Toyota parts sale. They should all be here today. Also considering upgrading to BP-51s at the same time. Is there anything else I should just go ahead and replace while I have it apart? Any other bushings I should be checking? Maybe replace the tie-rod ends? Open to suggestions.
i was gonna suggest the inner and outer tie-rod ends since youll be needing an alignment anyways. Might as well do one install and one alignment.
Not bushings, but cam bolts are usually rusted to crap, might want to snag new ones
how are your sway bar bushings?
I recently installed SDHQ stainless steel & extended brake lines since I did some suspension work. Definitely helped with pedal feel.
