which wheels for low pressure
Discussion in '40- & 55-Series Tech' started by theo, Feb 18, 2004.
  1. theo
    theo
    1,432
    1
    Feb 19, 2002
    Have any of you ever had problems with your wheels spinning inside the tire while aired down? Just wondering if Rock Crawlers or other popular non-bead lock wheels are knurled or machined in some way to help prevent this.
    thanks,
    theo
  2. pygpen
    pygpen
    472
    1
    Dec 9, 2002
    Benicia, California
    I've never had this problemon the cruiser, even aired down to 5 psi with 35X12's on 8 inch rims.
    I did have a problem with this on an old firbird I used to have :D
    PMK
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    They are not knurled, and do not have anything special about them, other than the price.
    If you are going run a 12.50 wide tire, I would mount them on an 8" wheel, to increase the force that the tire is putting on the bead area, even at low pressure, a 14.50 wide, I would use a 10" wheel, and so on.
    Running low air presure with a 12.50 on a 10" wheel, will lead to the bead area getting things wedged into it(dirt, sand, mud, small stones, etc) in low air pressure, and sometimes high pressure off road situations, creating leaks and a overall pain in the butt.
    Could just be me....but I do not think so...
    Good luck!
    -Steve
  4. theo
    theo
    1,432
    1
    Feb 19, 2002
    Always wanted a firebird!
    I've been thinking I want 33 x 10.50s. So I figured an 8" rim would be about right. That wouldn't put as much outward pressure on the bead like you recommend, but it might reduce the amount of sidewall bulge. Or maybe I shouldn't worry so much about bulge? (It's just that I'm getting a little too familiar with my own personal bulge. :D)
    I'm a dork when it comes to wheels. I thought Rock Crawlers were popular because they were stronger than others. Is it just that they look cool? Couldn't be. Not sure which ones I should be looking at, just don't want chincey.
  5. Poser
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    Just a name, they are not implying any more strenght...
  6. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,005
    95
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    The most Popular Steel Rim in Australia is easily the ROH Trak II, But is'nt availible in Black so they get the US Wheel Rock Crawler at about twice the price. :banana:
  7. pygpen
    pygpen
    472
    1
    Dec 9, 2002
    Benicia, California
    [quote author=theo link=board=1;threadid=11740;start=msg106954#msg106954 date=1077137713]
    [/quote]
    I think they are popular because they are cheap, durable, and repairable on the trail with a BFH. unlike aluminum.
  8. erfworm
    erfworm
    359
    30
    Apr 10, 2003
    theo, I have 35x12.50s on the 8 inch rockcrawler rims and air them down all the time haven't lost a bead yet, even at 4 psi pushing snow drifts all the way up to the sheep mountain traihead two weeks ago. I would think that if you are going to run 33x10.50s you could get away with using stock 6 inch wide rims and essentially have the same effect as the 12.50 on an 8 in. My roomate runs that set up on his 80. P.s. I have stock FJ62 wheels kicking around :D
    Nick
