Which fuel filter for 1HZ, where to buy?
Ontario, Canada
Looking to change the fuel filter in my HZJ73. Can anybody tell me which fuel filter I need to use and where I can buy one?
Thanks!
Peter
you can get them from ENS or your local Toyota dealer, same one for the 2LT/2LTE/PZ/3B (with rotory pump)...
i don't have the number handy.
so you got it and... are you happy? got any pics (or maybe i missed this thread)
Stock 1HZ Toyota fuel filter prt #23303-64010
For aftermarket the following part numbers
Donaldson P550385
Baldwin BF7535
Luberfiner G2920
Wix 33138
For 1HZ engine oil filter- toyota prt #90915-30002
Donaldson P550597
Baldwin BD7029
Luberfiner LFP5971
Check with the local toyota dealer on the oil filter,locally it was the cheapest over the counter price about $26.00
For the 13B-T
Aftermarket engine oil filters
Napa 1515
Fram,Luberfiner PH8A
Donaldson 550008
Baldwin B2
if you like you can also go with a old Ford tractor engine filter part #PH299(usually cheaper),they have all the same specs as the PH8A style filter but are 1-3/4"(45mm) longer
Aftermarket fuel filters
Napa 3398
Donaldson 550225
Baldwin BF954
Luberfiner LFF3553
Nissan FL403-Z9005
Aftermarket air filter 13B-T also 1HZ
Napa 2159
Donaldson P526756
Baldwin PA2042
Luberfiner AF368
James...
Or buy the conversion kit and use the Delco and Raccor style filters at $5-6;)
hummm, conversion kit...
got a link, i must have missed this.
(although i like the factory setup and have had no problems to date)
Donaldson P550385
Baldwin BF7535
Luberfiner G2920
Wix 33138
Donaldson P550597
Baldwin BD7029
Luberfiner LFP5971
cruiserdan had the 90915-30002 oil filer for under $11.00 USD and the 23303-64010 fuel filter element for under $21.00 USD. Downside is that he ships UPS and UPS behaves like thieves when calculating their customs brokerage fees.
-Steve
I like the factory set up too and you still use the OEM filter head . The adaptor fits onto the OEM head and then you can use the less expensive delco lucas type filter.
Its also for Nissan and Landrover.Quite popular in oz. They pop up on ebay reguarly
http://www.dencodiesel.com/products.asp
There are much better oil filters than the Fram PH8A.
For example:
Donaldson P550008
high flow P169071
Purolator Premium Plus L30001
Purolator Pure One PL30001
Motorcraft FL-1A
The internet oil filter comparison rated the Purolator filters as the best of those commonly available with the Motorcraft a close second as it's made by Purolator for Ford.
Has anyone tried the Donaldson high flow P169071 ?
