Which Engine, Too Many Choices
Georgia
Hey fellas, first thread into the diesel board.
I am planning a build that should probably be in another section but the engine questions belong here. This truck is going to be an all-around vehicle. Street driven somewhat capable in rocks and mud but not dedicated to any one offroad area.
here is a list of what I want to put in/on it:
Fj40 frame
Fj45 cab
flatbed
Dana 60 front/rear
tires in the 36" range
SM465
np205
diesel engine???
What engine would be best in this setup. I am wanting something very tough and dependable and still have parts available locally. And I think I have picked out the axles and trans/tcase for that goal. Diesels are tough dependable but I do not know about the different engines or if they are any that could even be bolted to a SM465. I do not want a Chevy diesel from a the 80s-90's I have not heard anything good about them.
Any help would be appreciated.
Probably the cheapest way to go would be a Cummins 4BT.
In the Toyota range, I sure like the ole 1HZ. No replacement for displacement.... That said, Id look at a 13BT pretty hard as well.
On the Toyota side, the 1HZ will be your best bet for a current engine
and regular parts availability.
Welcome to the diesel board.....:beer:
But the key question is compatibility with the SM465 and easy local parts availability... Are the Cummins compatible?
Here's some threads to read. I believe the Chebbys get better over time.
https://forum.ih8mud.com/search.php?searchid=1695126
https://forum.ih8mud.com/showthread.php?t=114060&highlight=chevy+diesel
HTH
B
Sure that 4Bt will bolt right on up to that SM465.
anycase you have pretty much adapters and stuff available with this engine.
