Which Brand Ring Gear To Buy???
Olympia Wa
I know it has been discussed before but it seems like there is always someone that has had a good or bad experience with something. So with that in mind I have a 78 fj with a 4 inch skj jacker lift and longer shackels. I have 33's now and may go to 35 someday but no larger. I have an arb to install in the front and a locker for the rear. Since I will have the 3rd members out I guess now is the time to re-gear. So, what brand do I get and I guess suggestions on gear ratios also. 4.56 or 4.88. kind of want to get into a little rock crawling but nothing to extreme.
Hi All:
I'd suggest going with a 4.56 ratio gear set. It will be fine with 35s, and not too low with 33s. The 4.88s will be waaay low with 33 inch tires! :eek: I have a buddy that has 35 inch tires and 4.88s and he wishes that he had gone 4.56 ratio instead because of the high RPMs on the highway.
For brand, I dunno. I'd suggest buyer the gear set from a reputable 'Cruiser shop, and follow their advice. Someone like Kurt @ Cruiser Outfitters in Utah.
Good luck with your rig!
Alan
4.88s if you plan to go larger. Just do it once. Low gearing is much more satisfying than low highways RPMs.
