Where to tap ignition-switched power? (1 Viewer)
An Add-a-Fuse is too large to use in the inside dash fuse panel with the fuse panel cover on.
What other methods / locations have others used to tap into ignition-switched power?
My preference is NOT to splice.
cartercd
Chandler, AZ
The cigarette lighter is ignition-switched and fairly easy to access. You would still need to splice, but at least you aren't splicing into anything that critical. It isn't a very high capacity circuit, however. I used this circuit to activate a relay on my auxiliary fuse block.
