Where to mount an air tank?
Discussion in '80-Series Tech' started by shanegtr, Feb 25, 2007.
  1. shanegtr
    shanegtr
    96
    Jan 15, 2007
    Perth, Western Australia
    I've tried searching but couldnt find what I was after. Has any one got any photos of where you mounted up your air tanks. Im going to be using a modifed 9 litre fire extinguisher. Looking under the cruiser this arvo and theres not really any free captive nuts in the chassis. Im not going to put it where the spare used to sit, as that will be taken up with fuel tank shortly. I was thinking behind the bullbar where the winch would normally be.
    Any thoughts
  2. loquito
    loquito
    838
    4
    Aug 6, 2004
    That is where mine is.
    And there is still room for the winch.
    http://www.george4wd.taskled.com/compressor.html
    not my sight. look twards the bottom for the tank.
  3. 98 SNAKE EATER
    98 SNAKE EATER
    4,572
    812
    Aug 10, 2004
    Queens, NYC and sometimes Orlando, FL
    On my Previa, I had one mounted in a case on the roof....
    [​IMG]
    But for the LC, I plan on mounting 2 tanks directly to the rack....
    Rick
  4. shanegtr
    shanegtr
    96
    Jan 15, 2007
    Well I think Im going to put it under the passanger floor(US drivers). I found a couple of captive nuts in the chassis that will do the trick and its not going to take up any space thats likely to get used for anything in the future. Should be a simple bracket to make up as well which is a bonus
  5. Aussie cruiser
    Aussie cruiser
    469
    Dec 20, 2004
    Brisbane Australia
    I originall had mine behind the bull bar. I used a set of Rhino pole carrier brackets to mount it. When i changed to a whinch bar and winch i moved it to the rear cross member as the spare is on tyre carrier. Shoud be a pic in write up for ROTW
  6. DanKunz
    DanKunz SILVER Star
    9,912
    Media:
    2
    Albums:
    1
    1,244
    Feb 7, 2002
    Woodstock, GA
    air...
    I have mine up under the rear since I have no plans for aux tanks and the spare is on the rear bumper:
    [​IMG]
  7. shanegtr
    shanegtr
    96
    Jan 15, 2007
    Change of plan again:rolleyes:
    Im going back to behind the bull bar, however Im now making a custom stainless tank. SO it should leave enough room for a winch if I ever get one. Sticking it up its bum like DanKunz would be good, but once I put the 190L fuel tank in there it wont have any room:lol: . Making this air tank has got me thinking about making a water tank as well - which is why I went back to behind the bar for the air tank - I can make a bigger tank for the water under the passangers floor
  8. cpg
    cpg
    679
    3
    Dec 27, 2004
    Livermore , Ca.
    mine is behind the bullbar
  9. alia176
    alia176
    10,505
    Albums:
    1
    909
    Aug 21, 2003
    Tijeras, NM
  10. Dusty
    Dusty
    2,595
    45
    Oct 7, 2004
    i've been looking into this also. There seems to be enough room for a long 6" (2 gallon) diameter tank running just above the spare tire support up under the back of your truck. you could keep the current spare if this is done
  11. shanegtr
    shanegtr
    96
    Jan 15, 2007
    It was a mission welding the tank up, but I had nothing better to do a work on nightshift:D Turned out I only had 2 pinhole leaks which showed up at the hydro test. I tell you what, pressure testing your own welding isnt the most fun I've had
  12. DTAYLOR
    DTAYLOR
    1,029
    3
    Feb 20, 2006
    Texas
    You boys got any concerns about what might happen if those air tanks explode?
    Seems like having them in the sliders and under the passenger compartment would be a bit risky.
  13. alia176
    alia176
    10,505
    Albums:
    1
    909
    Aug 21, 2003
    Tijeras, NM
    nothing will happen when any of these tanks sprout a leak. The air would simply hiss out. If you are able to bust open a .120" (some even go thicker) wall thickness sliders then you may have other issues!!
  14. DTAYLOR
    DTAYLOR
    1,029
    3
    Feb 20, 2006
    Texas
    So, I'm safe with the air tank sliders? I like the idea of a multi-tasking slider.
    Step, armour, and air. Very nice.
  15. alia176
    alia176
    10,505
    Albums:
    1
    909
    Aug 21, 2003
    Tijeras, NM
    Yes, you'll be fine! This concept has been around the 4x4 world for years. So many roll cages, tubular bumpers, etc have been used for air reservoirs!
  16. DanKunz
    DanKunz SILVER Star
    9,912
    Media:
    2
    Albums:
    1
    1,244
    Feb 7, 2002
    Woodstock, GA
    My tanks under the rear are from a contractor compressor setup...they are as thick as scuba tanks. If I hit one hard enough for an explosive failure I have two problems: 1) I hit it too hard, 2) something was wrong with my 150psi pressure switch.
  17. C6H12O6
    C6H12O6
    1,471
    Media:
    15
    Albums:
    1
    470
    Dec 23, 2004
    Beaverton, Oregon
    The MetalTech sliders have a couple mounting tabs upon which you can mount an air tank. Check them out if you haven't already built/bought sliders. Pretty sweet.
