Where to mount air compressor
Chandler, AZ
I am having an air compressor (ARB) installed in my 100. It currently will be used for airing-up tires and inflating air mattress, etc... but in the future (couple years) I will likely add lockers (fr, rr) ... so for those of you with ARB lockers where is the air compressor mounted? A pic would be great!
Thanks
Chandler, AZ
That's where it looks like there is the most room. I was wondering, and picture would mean a thousand words here... is there some particular angle they did it at, or is there a custom mount that was built ... I see that Slee sells a special mount for the 80 but not the 100.
macneill
Rollin’ on 33s
Port Washington, NY / Edgartown, MA
No pix, but I think on the passenger side close to the firewall is a bunch o' space. The LX guys have some sorta gizmo there, but I think on the LC, you should be fine.
You getting lockers on us bro?!!!!!
spressomon
glutton
Moderator
Northern Nevada
You mean where the second battery goes?
Chandler, AZ
Nice John... I apperciate the pics, its exactly what I needed! Thanks!
Looks like there is even room for the second battery... for later.
Landpimp
GOLD Star
Gig Harbor WA
thats is where the 2nd Slee battery tray would mount.
are you using the new ARB small compressor(which is only used to run the lockers, not to air up) or the older bigger one(like Shotts)?
ShottsUZJ100 said:
My 100 needs a full detail. YUCK!
Chandler, AZ
I think there is only one type of ARB compressor whiich is installed: RDCKA... the others are the portable kind. Here is a pic... looks like Shotts
Chandler, AZ
Looks like you have the non-US air box (looks bigger and more extreme) this takes up more space. If look at how Shotts compressor is mounted the compressor stays foward of the fender body panel bolt, which is roughly where the 2n battery tray is in stalled. It seems key to to keep the compress foward of the lower pre-existing bolt on the bottom side of the tray. Than one could do both the compressor and right behind it the second battery. Then the only catch is to find a different spot for "big round red swithch-y looking thing" in Slee's install pics
Question to Christo: In that 2nd Battery install (looks like your white LX) I don't remember you mentioning having installed lockers... So if you have 100 with your dual battery set up, where do you put the compressor?
Landpimp
GOLD Star
Gig Harbor WA
sure it will work, I have used mine many times, not too fast but it will do it. Prolly 5-10min to do that.
ShottsUZJ100 said:
So you guys think mine is decent enough to air tires? How long per tire? 16-35PSI...315s
Philippines
rzpapp, i actually had the 2nd battery installed in front of the air box. i bought the battery tray just for the arb compressor to inflate my tires. i dont really mind about the position of the compressor as long as i am comfortable to attached the hose. as you can see the picture again i had the quick release valve installed and no solenoid. :grinpimp: aren't you going to show us how you install your compressor? ;p goodluck.
Chandler, AZ
Ok the compressors in. Thanks for the pics on the placement. I have it right next to the air box foward of the bolt where the slee battery holder would go so I can install the 2nd battery next to it. Note the factory looking install on the switch, it fit in the single empty spot next to side view mirror controls. And it looks like the 2 locker switches will fit on the other side of the controls (a bigger empty spot)
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
