Where is your oil pressure?
Discussion in '40- & 55-Series Tech' started by billdance, Jun 29, 2005.
  1. billdance
    billdance
    121
    May 15, 2005
    Tirana, Albania
    Mine is just below the lower mark....is that normal?
  2. ken_79-fj40
    ken_79-fj40
    1,424
    40
    Jul 2, 2002
    New Hampshire
    Mine rides right below the lower mark too at cruising speed. I always have thought that was a bit low, but I have never put a real gauge on it to know. Been that way for the last 15k with no problems though.
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    autometer mechanical insturment reads about 50psi at 55mph...
  4. e-man
    e-man
    143
    2
    Mar 28, 2005
    Fort Worth
    Mine stays below the low mark too. I was running around 4 quarts low on oil and it didn't change at all when I filled it up.
  5. pbgbottle
    pbgbottle Forum Lifer
    4,783
    Media:
    92
    Albums:
    5
    437
    Feb 8, 2004
    Cloverdale B.C. Canada
    small block chev stock 40 gauge new sender . when cold above the higher mark .when warm almost right in the middle of the marks closer to the high mark
  6. Pighead
    Pighead Stop calling it an FJ
    7,592
    646
    Aug 31, 2004
    Denverish
    Stock gauges are a joke.
    Mr. Autometer sez 55 psi at speed...
  7. 72FJ40LandCruiser
    72FJ40LandCruiser
    142
    Jun 2, 2005
    I bought a cheap ass oil gauge to check mine... Haven't put it in yet. I was worried myself also because mine rides just below the second mark at cruising speed when warm. One day it was around 95 out and we drove out to the Palo Duro Canyon and at idle it was down to the lowest mark. I had just put in Castrol Syntec blend 10w30 so I was considering moving up to 10w40. What does everybody else run?
  8. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    27
    Jan 22, 2003
    Kansastitty
    I run 40wt in the summer and 10-40 in the winter. My oil pressure is always at the high mark but drops just below the high mark after highway running for a while. I thought that was an indication of worn cam bearings. Could also be that my gauge is just BS'n me to the high side.
    I think it takes 20psi minimum to get oil everywhere.
    Ed
  9. BigRedFJ40
    BigRedFJ40
    599
    7
    Jun 13, 2005
    East Glenville, NY
    autometer gauge reads 60 psi while driving at speed.
  10. Godwin
    Godwin Resident Herpetologist SILVER Star
    4,572
    5,937
    Dec 4, 2004
    Alabama
    Rebuilt 2F, Autometer mechanical gauge, 60 psi at anything over 1k rpm, at idle ca. 40 psi.
  11. brian
    brian SILVER Star
    9,187
    2,737
    Feb 7, 2003
    lebanon,pa
    i also hang right around the 2nd mark, anything from just above, to right over it.
    at warm idle the needle drops pretty far down.
    she don't knock or make any funny noises, so i guess all is well.
  12. Rice
    Rice
    4,631
    Media:
    10
    Albums:
    1
    5,765
    May 2, 2003
    GSO NC
    As mentioned the OEM guage will tell you there is pressure but little else.
    To answer your question I run 50 psi hot using 10W30 Mobile 1 and have bypass spring set at 70 psi for the cold mornings. (SBC)
