where is the speed warning buzzer on a hilux?
too bad it isn't just a fuse?
how long will it take? is it easy to find or identify when the cluster is out? is there anything I should watch out for, or anything I can really screw up doing this?
thanks.
mika
I had about 20 different scrapes on my arm trying to reach behind to hook up the speedo cable after I was done removing the chime. I had to unbolt the speedo cable from the driver's side inner fender well (it passes through a metal clip) to get enough slack to do it. I'm not sure if the 89 will be the same.
Mine was a little metal box with 2 yellow wires coming out of it.
